PRO EFI SPECIAL Wicked CAS (sample price Supra TT)
Other makes and models available, as well as Flying leads.
On NEW orders placed from today through next Friday 12/2/2011 with COMPLETE kits, you will get one of the following for free.
Color CAN Display or
Flex Fuel Sensor or
... ... CAN Cable
So a complete kit is:
128 ECU
+ harness
+ map sensor
+ wideband sensor
+ Fuel Pressure sensor.
So you get either a FREE Can display, or a FREE Flex Fuel Sensor, or a FREE Can cable.
$2990.00 ...WOW... FREE SHIPPING OFFER ENDS 12/2/2011
BMW E46 ProEFI special also available
IS300 ProEFI special also available.
You can add a boost solenoid and i-Boost 5 way selectable boost switch to the package for $200
We will be happy to make an appointment for your install at Wicked CAs and tune at Granite State Dyno & tune.
Call 603-642-4222
Also available for
Nissan R35 GTR
Nissan 76 Pin Skyline
Porsche 996
Porsche 997
Nissan VQ35
Nissan 240SX
EVO 8 or 9
Mazda FD RX7
Mazda Miata
GM C6 Chevrolet Corvette
GM C5 Chevrolet Corvette
Ford Mustang V8 99 to 04
BMW E46 Adapter (Boost Control with Cruise control buttons)
BMW E36 Adapter
VIPER Gen II
VIPER Gen III
Call us for pricing. 603-642-4222 Ask for Nazar
We are Massachusets and NH Area ProEFI Dealer and Tuners with GSD.
We are proud to carry PROEFI as our Engine management choice.
Many advantages over other systems.
The ProEFI Pro128 Toyota Supra Plug and Play system gives the user control over the following options
Fuel
Ignition timing
I-Boost Control (5 stages of boost curves that can be selected to be targeted against Vehicle Speed, Time, or Flex Fuel input)
Flex Fuel (ability to run any mixture of E85 with the ECU making on the fly adjustments to boost, spark, and fueling based on Ethanol content).
Antilag Boost control - 5 different target boost levels
TwoStep Launch Control - 5 different target RPM's
Hi/Low Octane switch - Allows the user to easily change the calibration to run pump gas and race gas settings
Nitrous Control - up to 4 stages
Control multiple fuel pumps in stages for easier fuel pressure control at lower flow demand
Automatic Transmission control with converter slip calculations to help with converter selection and seemless converter lock up engagement.
Manual transmission Gear position indicators and clutch slip calculations
2 channel Knock control with knock windows and true knock frequency filtering
Direct Fire Ignition - No wasted spark!
Fuel Pressure Feedback and fault control to monitor proper fuel delivery to prevent engine damage due to fuel system failure
Oil Pressure monitoring to alert when low oil pressure conditions occur
Radiator Pressure monitoring to warn for excessive coolant pressure in case of a weak head to cylinder block seal, or cracked cylinder.
Traction Control - Utilizes the stock switches and indicator lights for differential wheel speed front to rear.
Closed Loop O2 Feedback with Internal Wideband O2 sensors
Multiple Fault Management strategies to save the engine and alert the driver incase of sensor failure or tuning errors
CAN Display connectivity - 52mm Can Gauge, and 4.5 x 4.5" CAN display.
Meth injection - ability to control methanol injection and tune appropriately for it.
