Thread: Laser diffuser installation
Results 1 to 20 of 27
  1. #1 Default Laser diffuser installation
    I'm starting the installation of my radar detector and laser diffuser in the wrx. Its an passport, not sure of the model. It came out of the cayenne.
    It has a hidden radar that installs behind the bumper, dual diffusers in front and a single in the rear.
    Any who, I accidentally broke off one of the plugs off one of the the laser diffusers. Is this just a regular phone connector? Easily fixable?
    Do you have a picture? Most likely it is, and if so go to any IT department and they should be able to crimp a new end on for you. Just make sure to compare it to the other diffuser so you line it up right.
    just go to radio shack and buy the connectors. I have a crip tool for phone jacks and RJ45 connects. Bug me to bring it thursday.
    also, i want to see where you install yours. I'm going to get a laser system someday.
    Make sure to install close to the headlights and center plate. Placement is key.
    They're rj-11.. ;)
    derp... didnt see your responses. Tomorrow im going to retackle this. (and install my hellas lol)
    I have the rear one mounted....cinch.
    The front dual I mocked up, but it appears that I may have them too low according to what I have been reading. I mounted them to the cross member that the radiator is resting on. easily accessible through the front grille. Once i have the front grill off, I may look for other locations to mount these.
    As for the radar unit, per the suggestion of a nasioc member, im mounting it right in the air scoop lol.
    Quote Originally Posted by Intheflesh View Post
    Air scoop is a good place for it.
    You want your jammers as close to the headlights or front license plate as you can get, as that is what the cops aim for.
    what about the radar unit? does it need to be completely exposed?
    Ignore the STI, the front grill on my car is pretty much the same. can i mount it behind that plastic piece that goes down the middle?
    I do like the idea of mounting it in the air scoop, but I would like it to be more discrete, in the odd ball chance im driving through one of the states where radar detectors are illegal.
    If its just for the detecting, you should be able to mount it inside the cabin if you want, yes/no? What model? Valentine? Passport? Escort?
    its an older passport SRX. the radar is a 'stealth' module; its the one in the upper right hand corner.
    I did like how NOTHING was visible in the car on this set up, but the technology is old.
    I have been throwing around the idea of selling this set up and getting a blinder hp 905 and paring it with a V1.
    Passport 9500ix.
    Love mine. I'd never consider one without GPS after using mine for a year.
    If you want the best laser defense laser interceptor is the way to go then pair it up with a v1 or 9500ix for radar dection
    This. Seriously. I've been lasered at well over arrest me speeds a few times with my laser interceptors and I've had no issues.
    I just realized I left my 'concealed unit' in the cayenne. It's basically just a dual colored LED, with a lead and an rj22 connector on the other end. I imagine it shouldn't be too hard to wire another one, but I just don't know the pin outs. There's probably a resistor in there too that I'd need to know the value of.
    Or for $30, prolly easier to get another one from escort
    Been searching, can't seem to find one!
    Derp.., I have the same unit on fcar. Can just use a test light to check the pint outs
    Call Escort.
    That's what I'm going to do today. If I cant order one, I'll resort to reverse engineering one.
