Thread: The Triumphs 2013 Re-Paint
Results 1 to 13 of 13
  1. #1 Default The Triumphs 2013 Re-Paint
    So I started this a few weeks ago and even though its close to being done now I figured I'd share with you.
    Decided to try my hand with some carbon fiber. Mistake one... lol. I had done some work with fiberglass in the past, mostly small bits, and figured this couldn't be all too hard, boy was I wrong. I ended up having to change my original idea a bit because the cf got screwed up, anywho, here are some pics.
    The almost finished product.
    After adding some filler to smooth out the edges and rough spots
    Primer
    Mixed up my own color of red (not really anything crazy, just some bright red and a bit of black to darken it up)
    Got all the red base coat sprayed
    Added a metallic mid-coat
    And here is the carbon reveal (still needs to be cleaned up from the tape and wet sanded).
    Next step will be to wet sand to 2k and finish it off with a clear coat.
    I also plan on having the lines where the paint meets the carbon pin striped with gold leaf, the wheels will be finished in either black or gold (haven't yet decided), and the seats are being re upholstered in a carbon look cloth.
    --- 2000 360 Modena F1 --- 1979 Fiat 124 Spider --- 2014 Wrangler Unlimited --- 1980 Yamaha XS650 Bobber --- 1979 Yamaha XS750 Cafe ---
    (Prior)
    --- 2011 S4 --- 1990 Eclipse GSX --- 2005 Mustang GT --- 1992 3000GT VR4 --- 2007 Triumph Daytona 675 ---
    ---Lots of Trucks---
    cool idea. the gold leaf will set it off
    Bath salts and dick pills
    Damn, that's pretty awesome
    Thanks, I'm just worried about turning it into a fire truck.
    (Prior)
    black striping will be better
    Quote Originally Posted by Trptguy View Post
    I want something to break up the black from the red. I chose the gold leaf as the factory powder coat on the front forks and the brake calipers is gold, as well as the rear spring (more yellow, but w/e).
    If I were to paint a pin stripe on it would either be white or silver.
    (Prior)
    Final clear coat.
    This is the one piece that got screwed up, should still be fixable with the gold leaf.
    (Prior)
    Started putting things back together.
    (Prior)
    Is where the carbon meets the tank hidden?
    Do you mean where it is painted over? Yes, it is blended into the metal with some light body filler.
    (Prior)
    Just got the seats back from upholstery.
    (Prior)
    And shes done:
    Will go get some real pics with the DSLR tomorrow, after I fix a fuel leak.
    (Prior)
    Here are some shots from today.
    (Prior)
