Taking Pre-Orders for Friends only. $150 Transfered at our FFL
Pick a Serial number between 0002-0100. Will reserve them for you if it has not already been taken. You have first pick before I go live with the buy but we will need to have the money in hand to lock in your request.
-7075 T6 Billet Aluminum
-Broached Mag Well
-CNC Rotary Engraved to ATF Spec
-MIL-A-8625 Type III Hard Anodizing (Black)
FEATURES:
1) Captured Takedown Pin Spring (threaded hole WITH HARDWARE INCLUDED)
2) Left side of safety selector hole notched out for BAD_ASS ST 45 degree short throw levers to drop in with no modifications Engraving will also accommodate 45 degree (BAD) 60 degree (Noveske) and 90 degree (Standard) selectors
3) Upper tensioning screw behind pistol grip screw (threaded hole with hardware included) to adjust any slop out of vertical fit between upper and lower
4) Ambi trigger finger rests with grooves (above and below mag release / mag catch)
5) Compatible with Norgon and other aftermarket ambi mag releases
6) Threaded bolt catch pin! (Threaded hole and hardware)
7) Drop free magwell design with beveled bottom lip
8) Front of magwell traction/finger grooves
9) Integrated large opening "winter" trigger guard
10) Accepts all standard LPKs, KNS pins, etc, etc.
