Thread: Wheel Hub Removal (Subaru... of Course)
Results 1 to 16 of 16
  1. #1 Default Wheel Hub Removal (Subaru... of Course)
    The Subaru has had a bad wheel bearing for a while. I have been avoiding the job because I hate working on that car. Nothing ever goes right with it and in the end it's a winter beater anyway.
    The bearing was getting louder and had not healed itself over the summer. Since winter is coming I figured I'd swap it out. It's worth noting here that the part is $85 from rockauto and close to $300 from autozone. WTF, autozone?
    So this morning I went to swap the bearing. I got pulled off the wheel. My harbor freight electric impact gun zipped the CV nut right off. With a little effort I got the four bolts that hold the bearing in removed.
    But the hub won't come off. Hit it with a hammer... hit it with a bigger hammer. Went at the seam with a chisel and hammer. Bought a slide hammer from HF and after filing down the wheel stud adapter for an hour so it would work with the Subaru's bolt pattern I went at it, convinced I had it beat.
    No luck. Hasn't budged.
    Things I do not have: welder, acetylene torch or a shop press.
    Does anyone have any tips for getting this fucker out? In lieu of advice, words of encouragement are appreciated.
    So you can't get the bottom half to release from the top? Is it still on the car?
    Have you soaked it in PB Blaster? I'm not familiar w/that setup but depending how long you drove it for the bearing could've welded itself in place. With that design I'd just replace the hub and bearing assembly (is that what AZ is selling you for $300?).
    A torch would be your best bet here tho. Heat up the area, give it a couple taps and try the puller at the same time. Someone you know can bring you one or you just throw it back together and shoot down to the store?
    I'm trying to remove the entire assembly. The bearing itself (top of the part pictured) fits snugly into the steering knuckle. It's not a press fit, but apparently they rust themselves together. I've been soaking with PB blaster. I'll go at it a little later with the hammer and puller. I looked it up again on autozone and it's coming up around $150 now. I'm not sure if I was looking for a pair before.
    I don't want to torch. I'd need to pull everything off the car to keep the heat from damaging things around the hub. At that point I'd rather throw it in a press and be safe from burning myself.
    First I'd try penetrating liquid to see if helps. Second would be a blowtorch and the slide hammer.. If the slide hammer and a BFH still don't work, air chisel where the hub rusted itself to the knuckle. Bitches love air chisels.
    I have been hitting it with PB blaster since yesterday. I hope I can find a way to pry between the hub and steering knuckle so I can combine that with the slide hammer.
    Every job on this car seems to require a multi-day penetrant soak.
    I kind of miss the bearings on my old GMs. Pull a cotter pin, pack the new ($15) bearings and put them where the old ones were.
    Try Kroil if the pb blaster doesn't work.
    "It was more passionate than just cuddling"
    Thanks, I'll find some and give it a shot. I'm just resigned to seeing this thing on jackstands for the week.
    I had very high hopes for the slide hammer that quickly turned to disappointment. Well, not that quickly. It took a while to file off enough steel to get the adapter to fit on the Subaru bolt pattern.
    Aug 2009
    Quincy
    6,070
    bumping a 2 month old post. justin, any luck? lmk if you need help
    '00 GS300
    '08 IS250
    '05 IS300
    '73 240Z
    Photos
    Quote Originally Posted by Philsans5
    Wes get your hands out of there!
    spotted LFA in toilet, promptly flushed it
    Quote Originally Posted by MassBimmer View Post
    Hennessey
    Quote Originally Posted by the.wong.kid View Post
    I bought a shop press from Harbor Freight and got it out. Of course, once I took care of the noisiest bearing I can hear others.
    what year and model?
    OT, any tips on buying an 09-13 Outback ?
    Wheel bearings seem like a weak point. Not really weak, but expect to change them around 100k. Same for the front axles. There doesn't seem to be much wiggle room in the expected service life of a lot of parts on these. The parts go right about when the rule of thumb says you can maybe expect them to start failing.
    09 was the newest 5 speed we could find, but subaru has serious issues with their throw out bearings. The bearings themselves are shit and they also mount to an aluminum snout that gets all buggered up by the bearing. There's a relatively easy fix (stainless sleeve for the snout) but it requires pulling either the engine or the transmission (engine removal is the 'short cut'). So the auto version may not be so bad afterall.
    Headgaskets are an issue for the non-turbo 2.5. I've heard that it was addressed in 08-09, so maybe the newer model is a bit more dependable there. It's worth taking a look under the car to see if oil is starting to seep at the head/block junction.
    I only really post about the thing when it's a problem, but ours has never stranded us. It has caused us to drive around in a car making embarrassing noises but has not stranded us anywhere. All the features of the car still work. No real rattles or buzzes. It doesn't even acknowledge the existence of snow.
  12. #12 Default Love checking this site :)
    Love a good read of this blog Btw, if you want to know the best online casino in Indonesia, I highly recommend this terbaik agen sbobet forum along with this bagus bandar bola profile and this terbaik judi bola site and don't forget this hebat bandar judi online, not to mention this terbaik agen sbobet website along with this luar biasa bandar judi profile and this luar biasa agen bola site and don't forget this bagus bandar judi sbobet and this luar biasa situs judi sbobet page along with this baik judi bola online profile too! you may as well check out this luar biasa situs judi sbobet website along with this baik judi bola page and this hebat situs judi bola page and don't forget this baik bandar judi sbobet while you're there.
    Also worth a look are iron-fire.co.uk again, with their great sustainable bespoke industrial style outdoor furniture in the uk. Check these sustainable bespoke industrial furniture products as well as these sustainable tailored industrial style furniture details and even sustainable bespoke industrial furniture pieces together with green bespoke industrial chairs pieces, they're great.
    And, finally, dog enthusiasts need to see this superlative dog review blog for top tips!
  13. #13 Default Loved browsing this site :)
    Loved browsing this forum Btw, if you want to know the best online casino in Indonesia, I highly recommend this terbaik sbobet88 page along with this teratas sbobet login website and this bagus sbobet login site and don't forget this hebat sbobet login, not to mention this luar biasa sbobet88 page alongside this terbaik sbobet88 forum and this luar biasa sbobet88 website and don't forget this bagus sbobet88 and this teratas sbobet login forum along with this terbaik sbobet88 website too!
    Another excellent online casino in Indonesia can be found at this teratas idn play website along with this bagus agen poker online profile and this terbaik idn play site and don't forget this hebat agen poker online, not to mention this luar biasa idn play site along with this teratas idn poker website and this baik agen poker online site and don't forget this teratas idn play and this teratas idn play site along with this terbaik agen poker online profile too!
    One final casino to look at is this luar biasa idn poker site as well as this luar biasa idn poker site and even this teratas idn poker forum, it's great!
  14. #14 Default Loved browsing this site :)
    Loved browsing this blog Btw, if you want to know the best online casino in Indonesia, I highly recommend this terbaik situs poker forum along with this teratas poker forum and this terbaik situs poker site and don't forget this bagus judi poker, not to mention this bagus daftar idn poker site alongside this teratas poker online website and this terbaik daftar idn poker forum and don't forget this terbaik poker online and this hebat idn poker site along with this teratas poker online profile too!
    I must also suggest this good vintage wp template to check out along with this great retro wp theme to check out and this great legacy theme wordpress to peruse and don't forget this top vintage theme wordpress to see, not to mention this top wp 90s theme to see alongside this great retro theme wordpress to check out and this great retro wp template to peruse and don't forget this best wordpress 90s template to check out and this top wp 90s theme to peruse along with this great wp oldskool theme to check out too.
    Finally, I highly suggest this accept credit card payments online forum along with this credit card payment processor website and this credit card payment gateway website and don't forget this Bitcoin credit card payment processing, not to mention this magento credit card payment website alongside this digital credit card payment systems forum and this credit card payment apps website and don't forget this credit card payment solution and this taking credit card payments online page along with this international credit card payment processing profile too, not to mention credit card payment provider page along with this credit card payment processing services site and this gateway credit card payment page and don't forget this mobile credit card payment systems, not to mention this credit card payment gateways site along with this nutraceutical merchant account credit card payments profile and this digital credit card payment systems site and don't forget this taking credit card payments online and this forex trading credit card payment solution page along with this accept credit card payments on my phone site is great too!
    Big fan of this this page Btw, if you want to know the best online casino in Indonesia, I highly recommend this good my pay weekly site along with this cool beds on finance forum and this lovely my pay weekly site
    I would be remiss not to suggest this recommended site forum along with this lowest price forum and this a fantastic read forum and don't forget this my response , not to mention this click this link now page alongside this find out this here forum and this click here to read site and don't forget this get more info and this this hyperlink forum along with this previous site too! Also check out this her response profile along with this internet profile and this have a peek at this website website and don't forget this his comment is here , not to mention this helpful hints website along with this read review forum and this she said profile and don't forget this see this and this image source site along with this have a peek at this site site too! Also worth a mention is this you could try this out forum along with this visit this page forum and this website link page
  16. #16 Default Love checking this forum :)
    Loved browsing this forum Btw, if you want to know the best online casino in Indonesia, I highly suggest this top beds on finance site along with this best perfect home profile and this great beds on finance forum
    I would be remiss not to suggest this check out this site page along with this our website website and this what google did to me site and don't forget this read what he said , not to mention this check out here page alongside this see here now site and this you can look here site and don't forget this knowing it and this site site along with this read the article website too! Also check out this such a good point website along with this good website and this sources tell me page and don't forget this pop over to this site , not to mention this visit this page site along with this advice site and this additional hints profile and don't forget this she said and this the full details page along with this read what he said website too! Also worth a mention is this visit this site right here profile along with this webpage page and this look at here now forum
