Thread: EZ Flash - revolutionary tool for tuning-at-home by OE/Brentuning
Results 1 to 5 of 5
  1. #1 Default EZ Flash - revolutionary tool for tuning-at-home by OE/Brentuning
    Hello yr
    I just wanted to share a brief DIY of the very soon to be released EZFlash tool for most modern performance cars by OE Tuning.
    OE Tuning has announced that finally we have a map switching option for many of the popular German performance vehicles on the market. Many of you know that the S65 for example had to be flash tuned and no tuner on the market had the ability to provide different maps to account for different setups on the fly. That is, no tuner had the ability until today. OE Tuning is the first tuner to have a map switching option for the factory DME E9X M3 among many other models.
    So what can EZ flash do? It does not simply provide different maps. Here are the features provided by the product:
    - Tuning
    - Data Logging
    - Map Switching
    - DTC Reading
    - Code Clearing
    - USB connection
    - Remote download and upload of maps
    - No limitation on the number of tune changes as with traditional flash approaches.
    - Easy to use as the name implies
    - Competitive Price
    - The only product of its kind available for the S65
    Ok, I get that this is a big deal for factory DME BMW M3's with the S65, what about other models?
    Well, this is not just limited to the E9X M3 even though this product will be making huge waves in that respective market. The product already supports the following models:
    BMW:
    MSS60 - S85
    2008 - BMW M3 V8
    MSD80.X - N54
    2006 on BMW 335i
    MSD81.X - N54
    2008 on BMW 335i
    BMW models coming soon:
    MSD/MSV8X.X - N52+
    BMW X23i, X25i, X28i, X30i
    MSS65 - S85
    2006 - BMW M5, M6 V10
    MSD85 - N63
    BMW X6M, X50i
    The following Mercedes Models are supported:
    ME2.7
    2004 - 2006 MB CL/S 600
    2004 - 2006 MB CL/S 65 AMG
    ME2.8
    2002 MB C/CLK/E/ML/SLK 240
    2002 MB C/CLK/E/ML/SLK 320
    2002 - 2004 MB C/SLK 32 AMG
    2002 MB CL/CLK/CLS/E/ML/S/SL 430
    2002 MB CL/CLK/CLS/E/ML/S/SL 500
    2004 - MB C 55 NA AMG
    2003 - MB CL/CLS/E/S/SL 55 Kompressor AMG
    2005 - MB CLK/SLK 55 NA
    ME9.7
    2006 - MB C/CLK/CL/CLS/E/ML/S/SL 63 AMG
    Mercedes Models Coming Soon:
    ME2.7.2
    2006 - MB CL/S/SL 600
    2006 - MB CL/S/SL 65 AMG
    Below are pictures and details of my EZFlash process:
    When ordering an EZ Flash module you will receive this contents in your package:
    (1) EZ Flash ODB2 programmer
    (2) small mini type USB
    First thing you want to do is have your computer (Windows XP and up) recognize the drivers and accept the EZflash module via the USB port. At this point you can use it like a thumb drive but it will be empty (for now)
    Then you will want to marry it to your car, where the EZFlash will read your factory file and place it in the memory
    Next you will want to find the USB port in the picture below:
    By pulling on the tab on the OBD cover you will be able to remove it so the port is accessible in the picture below:
    Then have your directions ready via PDF file and follow the instructions which I will summarize below:
    Then with the key off you will want to place your EZFlash into the OBD port and make sure the toggle switch is in the factory position closest to the "line." This will read the factory file. Then you can proceed to put the key in the slot position (accessory mode - do not start vehicle) and the EZFlash will go to work automatically. It will blink red while it is working. After a minute or so the lights will signify that they are done when they blink between red and blue. When completed, you can remove the EZFlash and take out the key.
    From here you will notice the VIN is married to the EZFlash 3355) and it has pulled two files out of your car, a history report and the factory file ready to be tuned. These files will need to both be attached and emailed to uploads@oetuning.com. You will then receive a tuned file back via email and you can place it into your EZFlash by dragging and dropping into the folder while it is connected to your computer.
    With the files that are read the tuner can now see your software version, when the last time you were flashed, if you have competitor software or not, whether you are tuner protected DME or not, and other DTC and fault memory in your vehicle hindering max performance in your tune. This snapshot allows flexibility in getting the most from your vehicle to troubleshoot issues and seek advice from OE Tuning.
    Here is a screenshot of SOME of what your tuner will see (depending on cars history will have alot more then shown below):
    So, from here you can work in reverse, however you will switch the toggle switch AWAY from the line to revert to your "tuned" map and the car will now write, instead of read the factory file. So you would plug the EZFlash into the ODB port and put the key in the ignition and the light will go read during it's progress. From there when it turns green, it is all done and programmed. And you can now enjoy your vehicle. With both the factory file on your program and the tuned you, within 30-45 seconds you can switch the procedure between stock/tuned, or pump gas/race gas or however you want the car setup.
    ***PLEASE READ THE PDF for step by step detailed instructions as this is only meant as a demonstration***
    The introductory cost for a EZflash module is an additional $400 to the flash price of the vehicle.
    Questions or inquiries: sales@brentuning.com
    Bren Tuning - Unlimited Tuning Solutions
    Phone: 508.762.1769
    Skype: BrenTuning
    Web: www.brentuning.com
    Email: sales@brentuning.com
    i saw this awhile ago on another site, these guys seem like they are very good at tuning
    Hey im having a problem with my flash tool anyone have the pdf instructions...im hoping that helps me thanks
    Pretty awesome!! Thanks for posting, will definitely be looking into this once I start modding.
    sweet product.
    wish stuff like this was available for lotus
    Bath salts and dick pills
  1. BMW X5M/X6M Flash tuning +85whp +100wtq
    By Brendan @ BrenTuning in forum BrenTuning
    Last Post: 04-15-2011, 04:30 AM
  2. Pictures from BrenTuning Custom Tuning Event
    Last Post: 07-28-2010, 01:21 PM
  3. Flash-at-home Tuning kits in testing for BMW/Mercedes and more!
    Last Post: 01-07-2010, 11:21 AM
