Thread: stereo/nav help
Results 1 to 7 of 7
  1. #1 Default stereo/nav help
    I need some help with my avic system. I want to have the nav working with having to pull up the Ubrake.
    Any ideas??
    Not sure how to do it with your system, however my Eclipse has the same limitation. I added a switch to the line that permanently grounds the line so the nav thinks the ebrake is on all the time.
    Can you find the wire that is going to the ebrake?
    hahaha....yeah i can find the wire cause i ripped the wire off the ebrake. Now I just have the wire and need to ground it somewhere.
    Need to check the manual on the wire. Is it grounded or powered. Manual should help. 99% chance its a ground so just bolt to something and see if you can nav
    Near the RI border
    1,421
    We used to do that same thing, only add in a switch so it would function as designed if you wanted.
    Which AVIC do you have? they are all different
    EDIT: Don't just ground it.. If its a newer AVIC, you just move a pin on the harness...
    yup just moved the pin and it is all set.
    Thanks guys!!!!!
  1. Need a shop for trans am stereo fix
    By 05legacyturbo in forum Audio / Security / Video / Navigation
    Last Post: 08-16-2010, 01:18 PM
  2. good stereo installer ?
    By buzztt in forum Audio / Security / Video / Navigation
    Last Post: 10-21-2009, 10:55 AM
  3. Luxury Details 2002 Bentley Azure Stereo Install
    By Matt in forum Audio / Security / Video / Navigation
    Last Post: 03-05-2009, 11:58 PM
