Thread: Tanabe Why U Rust?!?
Results 1 to 20 of 36
  1. #1 Default Tanabe Why U Rust?!?
    So popped my hood yesterday to do some spring cleaning and found this:
    now i gotta figure how to stop it. I can either try and dremel most of it off and cover it in rust oleum or i can try and find a sand blaster and the paint it in rust oleum
    I'm guessing warranty won't cover rust? Never dealt with anything like this.
    Quote Originally Posted by steve0827 View Post
    not sure havent tried to contact tanabe yet. I had this thing for less than a year too
    That's the northeast for you, the salt just eats away at everything. I'd try a dremel with some polish on it first as it looks to be just surface rust. If not I can most likely fix it with some high grit sandpaper and the polisher on my porting tools.
    Like stated above its the salt around boston.. My car has salt spots on stuff i didn't even know could rust... lol
    I will probably be doing some rust treating this weekend, its so much fun... POR-15
    Well, if you ask me, it looks like a pretty generic strut bar sourced from Taiwan =) .. i bet Tanabe sent more time figuring out what logo sticker size would fit on it than the actual engineering of the bar itself
    leave it the way it is... adds JDM character
    Clean it best you can w/a wire wheel and hit it w/some rust reformer to stop it. Then sand that down and paint it.
    I used that rust reformer on my steering knuckles and it works great.
    start new hood ride trend? rusted engine bay?
    Easton, MA
    5,530
    most of that looks like surface rust. I'd remove and polish by hand first. Simichrome is awesome, but expensive. Pete suggested some other stuff also. That will at least let you know how bad it really is.
    I'm sorry to hear you suffer from Cranial-Rectal Inversion
    Older cars just have more soul
    Quote Originally Posted by 55Fanatic View Post
    Can you imagine if we had 2 Rich's on this forum? oye
    as already mentioned, take it off, clean it, then add some black rustoleum to keep it from rusting again
    Quote Originally Posted by leemik View Post
    Spent some time under the Pcar this week on the exhaust. Had to order some replacement parts. Never even drove it in the winter.
    Sep 2010
    Southern Maine
    4,376
    I would just buy some stainless heim joints and hardware to replace the steel end. Will cost more but will look better and last longer.
    Matt
    If you want to keep it adjustable, you probably don't want to paint the threads.
    If you want to paint it anyway, make sure it's installed right first to make sure it's not going to need re-adjustment. Remove one of the end bolts, jack up the front of the car from the center so the wheels go to full droop, then adjust out the ends so the bolt holes line up. Then you can just paint the hardware (mask off the section of the mounting bolt that will have the nut threaded onto it).
    In all, if you're worried about that amount of rust you may want to relocate. ;)
    White Hairdresser's Car, Orange Car with Hand-Built Engine (Like AMG) and 6-Speed (Not like AMG)
    Feb 2010
    Maine aka Canada Jr.
    882
    Quote Originally Posted by Justin.b View Post
    just use a good zinc based anti-seize paste on the threads and you wont have a problem with corrosion there.
    '08 Audi A5 S-line... 3.2L of ozone depleting goodness.
    Used the POR-15 on my car today... decided to rock a ghetto kick panel painted grey for a bit until I can get phil to paint it. That shit takes forever to dry, my buddy leaned against it and now I have to sand it and apply another coat tomorrow.. fml
    Boy that kinda sucks. The JDM Tanabe and GAB bars from back in the day (10yr ago) used to have stainless hardware. They've cheesed out in modern times...
    What most likely caused that is actually the oils from your hands when installing... The bolt/joint probably had some sort of oxide coating on them, and then when you installed it, the oils from your hands got on the parts, which allows it to rust... We use black oxide fasteners on our stuff at work, which is indoors, in controlled environments and they still rust sometimes...
    This. I wouldn't paint it if I were you either. When I used to play golf, I used to have this Scotty Cameron putter that loved to rust. Most golfers used baby oil to keep it from rusting. You could try that.
    2008 Honda Civic Si Sedan
    1998 Mercedes-Benz C43 AMG
    1991 Honda CRX HF
    might as well rust the hood now too...
    '86 325es - MTechnic I - s54tu
    '89 325is
    '08 RS4
    21,560
    Its not a VW tho
