Thread: Detailer's Domain: BMW 135 - Aquartz Applied
Results 1 to 5 of 5
  1. #1 Default Detailer's Domain: BMW 135 - Aquartz Applied
    This 1 series came to us in pretty good shape. Not much polishing was needed however a thorough cleaning was necessary and proper prep on the paint and wheels were needed to apply Aquartz and Opti Coat - something the customer was keen on as this is a heavily used daily and also sees the track time.
    What was done -
    Exterior
    - Wheels were prepped with Sonax Wheel Cleaner and cleaned up with various brushes
    - Tires were spritzed down with Adamís All Purpose Cleaner and washed down
    - Wheel wells were cleaned up
    - Pre Washed with W99
    - Iron Cut
    - Wash down and rinsed
    - Door jambs were cleaned up
    - Clayed
    - Dried
    - Tires dressed
    - Masking
    - Paint Measurement
    -1 Step - Sonax Perfect Finish
    - Inspection with Fenix, 3m Sun Gun, Infratech, and natural sunlight
    - Last Step Ė Aquartz (3 coats)
    - Wheels pulled off and treated with Opti Coat 2
    - Brake Calipers cleaned and treated with Opti Coat 2
    - Wheel wells were cleaned and dressed
    - Rubber and Plastics Treated
    - Exterior windows and mirrors cleaned and sealed
    - Exhaust tips cleaned
    - Windows were clayed, cleaned, and sealed
    - Jambs steam cleaned
    Links to products used -
    1Z einszett W99
    Iron Cut
    Adam's All Purpose Cleaner
    Sonax Full Effect Wheel Cleaner
    Adam's Undercarriage Spray
    Uber Clay Bar Kit
    Aquartz Nano Coating
    Optimum Opti Coat 2
    Adam's Super VRT
    Adam's Metal Polish
    Adam's Glass Cleaner
    Engine
    Adam's In and Out Spray
    Interior
    1Z einszett Cockpit
    1Z einszett Leathercare
    Tools used
    Uber Wool Wash Mitt
    Uber No Name MF Towels
    Flex PE14-2-150
    Uber Buffing Pads
    Defelsko Paint Meter
    Brinkmann
    Kranzle Pressure Washer
    Cam Spray Foam Canon
    2 Grit Guard Buckets with Caddies
    Uber Firehose Nozzle
    Metro Air Force Blaster
    Interior
    Before
    Metro Vac being used to clean up the interior
    After
    Exterior
    Before
    Wheels (this was 1 week of brake dust)
    Before
    Sonax Full Effect Wheel Cleaner to the rescue
    (more on the wheels in a few)
    Phil@DetailersDomain.com
    www.detailersdomain.com
    Please use "YUPPIE" at checkout for 10% off
    Current Specials
    How to's and FAQ's
    Engine
    Before
    Adam's All Purpose sprayed generously on the engine bay
    After
    Engine was dressed with Adam's In and Out Spray
    Bug and tar was evident on the nose of the car. I used the 1Z einszett Anti-Insekt Bug + Tar Remover
    After
    As you can see the Iron Cut was needed on this 1.
    The 1 was washed with W99 and then rinsed well.
    Clayed the windows and paint
    I was still able to pull contaminants off the paint
    Used 3m Adhesive remover to pull tar off the bottom of the car
    As mentioned before the car didn't need much in terms of correction. We used Sonax Perfect Finish to prep the paint for Aquartz
    On to the wheels, brake calipers and wheel wells
    Steam used to clean the caliper/wheel wells etc
    Opti Coat applied
    Adam's Super VRT on the tires
    After shots
    Current Specials
    How to's and FAQ's
    Apr 2010
    Jeddah, Saudi Arabia
    6,372
    amazing work as always
    Porsche 991 GT3
    Green/ Black Iridescent
    HRE P101-IPE Catless Exhaust- Techart Steering Wheel-991R/ Classic Livery- Carbon Fiber Exterior Package
    Houston, TX
    11,919
    Wow. That looks brand new now.
    I stopped a moment like that too... I wiped Mat's cheek cause he had nutella all over his face
    Wow. I'm sure it looks better now than when it rolled off the lot.
    BTW, what's that Iron Cut stuff and what does it do?
  1. Detailer's Domain: Audi TT - Aquartz
    By DetailersDomain in forum Detailer's Domain
    Last Post: 06-17-2011, 06:42 AM
  2. Replies: 1
    Last Post: 06-01-2011, 09:55 PM
  3. Detailer's Domain: BMW X5 4.8
    Last Post: 08-03-2010, 09:00 PM
  4. Detailer's Domain: 3M PPF on a 535
    Last Post: 10-14-2009, 10:40 PM
  5. Detailer's Domain
    By Admin_Pete in forum Special Thanks
    Last Post: 09-05-2009, 01:16 PM
