Thread: E36 headlights
Results 1 to 8 of 8
  1. #1 Default E36 headlights
    Any of you guys know if it possible to get to the inner lenses of the US spec headlights? i would like to stain the high beams yellow.
    1997 Boston green e36 M3
    2002 Aston green Triumph Daytona centennial edition
    Saugus, MA
    924
    Its a pretty straight forward job to remove the front lens from the main housing. Heat gun is recommended but most will tell you to use an oven instead.
    Their isnt some sort of "back door" on the assembly? Also im worried about condensation.
    Quote Originally Posted by E30sex View Post
    have the guy above your post do it for you. pro. tellin ya.
    Saugus, MA
    924
    Only thing that you can gain access to from the back of the headlight is bulb installation and removal. There is no way around the fact that you must break the "seal" on the headlights if you want to gain access to the reflector to "tint" them. If the light is disassembled/reassembled correctly you should not have condensation issues. You could also run a transparent film over the lens on the outside if you don't want to deal with taking apart the headlamp assemblies
    Here's a few examples of the transparent film;
    btw; most of the quality transparent films double as a protectant since most of them are usually anywhere from 8mm to 16+mm thick.
    Quote Originally Posted by Duey View Post
    hmm, Well ill give it a go. i think im going to pick up a headlamp from the junkyard for practice and then give it a go when im comfortable. thanks for the input.
    upgrade to euro, glass headlights??? They should make a pretty big difference.
    '86 325es - MTechnic I - s54tu
    '89 325is
    '08 RS4
    I just got the euro glass halogen headlights for mine and they are such an improvement over my previous headlights that I cant imagine going back. A yellow clear film would look great!
    E36 325IS 5 speed.
    "Le is not amused"
  1. e46 headlights?
    By nperkins in forum Performance, Interior & Exterior mods
    Last Post: 09-06-2011, 02:25 PM
  2. Headlights polished by Rick @ Unique Car Care in Wakefield...
    By LastMercury in forum Detailing and Car Care
    Last Post: 03-01-2011, 01:43 PM
  3. Replies: 16
    Last Post: 11-19-2010, 07:35 AM
